brake pedal hard after sitting awhile
JimBee
Has thanked: 25 times
Been thanked: 42 times
Post by JimBee »
The brake pedal in my '93 850 feels "stuck" at the top after engine has been off for awhile. Sometimes after just an hour or two if put my foot on the brake it is like stepping on a solid block and the brakes don't work. As soon as the engine is started, with normal pressure to activate the brakes, the pedal descends to its normal position and the brakes work. What might cause this?
jimmy57
Been thanked: 320 times
Post by jimmy57 »
Check valve on booster or faulty booster. If it is the check valve then using a pair of needle nose Vise-Grips to clamp the vac hose to booster while engine is running. Shut off engine and wait 10 or minutes and apply brakes. If pedal is hard then it is booster. If pedal still feels normal then it is check valve.
The booster shouldn't leak vacuum with pedal released and when engine is off the check valve should hold vacuum in booster.
JimBee
Post by JimBee »
Okay, so when I clamp the vacuum hose I'm emulating the check valve? Thanks, I'll give it a try.
jimmy57
Post by jimmy57 »
Yes, You are assuring the vaccum holds in booster if it has a bad check valve. You have to be sure the clamping is effective.
FireFox31
Has thanked: 158 times
Been thanked: 300 times
Post by FireFox31 »
I am having this problem and a related symptom on my 2000 V70 NA FWD. For over a year, when I shut off the car, I would sometimes hear a slow groaning sound coming from behind the steering wheel (the location of the brake booster). The sound would stop when I pressed the brake pedal and resume when I released it. After 30 seconds, it would stop. I could not reproduce this on demand and it happened infrequently.
A few days ago when I went to start the car, I stepped on the brake pedal and found it firm and not possible to depress. That lead me to this and other threads suggesting the vacuum line check valve is bad.
As recommended here, I clamped the line and the pedal quickly became firm. So this is a failed brake booster, not a failed check valve? The brakes work fine when driving. What about the booster has failed?
Or should I just replace the check valve and see what happens? I'm trying to properly diagnose this before throwing the $50 part at it. Thanks.
FireFox31
Has thanked: 1857 times
Been thanked: 1718 times
It is most likely the check valve. That bit of plastic does fail with age, just like most of my joints.........! :o :lol: :lol:
A junkyard part is fine. They don't fail all that often.
