PCV upper vent hose broken 2006 S60 2.5T
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
wsmuller
Year and Model: S60 2.5T, 2006
Post by wsmuller »
So, I've suffered the common problem of the broken upper vent/breather hose on my 2006 S60 2.5T. Did an oil change yesterday and as I was pouring the new oil in the filler, I barely nudged the hose and it just fell off. I just bought the car two months ago, so I don't really know, but it looks like it had been deteriorating for some time.
I plan on replacing the whole PCV system, but I have to wait for the parts to arrive and have to drive the car in the meantime. Is there anything I need to worry about or watch for as I drive it?
jimmy57
Been thanked: 320 times
Post by jimmy57 »
It will make a mess but you can wash engine after you are done and everything is sealed up. Also remove and blow out spark plug wells as these engine LOVE to get water down in there when you wash engine and the misfires usually happen later when you may have forgotten about the wash job.
Be sure the lower port that lets oil condensed in box drain back into sump is clear. This opening being plugged will not let oil go back and it will use oil but not have crankcase pressure problems as evidence of any problem.
wsmuller
Post by wsmuller »
I'm not familiar with this system at all, and I rarely do repairs like this myself, so could you explain and describe the lower port?
Thanks for the reply.
jimmy57
Post by jimmy57 »
You remove intake manifold and there is two small water hoses and a vaccum line running to a fitting at the front bottom of intake plenum. There is a hollow bolt with a check valve inside that needs carb spray cleaning to be sure it is clean.
With intake out of the way you will see the box I'm referring to. It will have an odd hose off the side that goes onto a largo port that crankcase vapors come from in addition to the cylinder breather hose that has cracked. There is a rear bolt for the box and a front lower one that is accessible using a 6 inch extension and 10 mm socket (I have found one car with 8mm heads, thanks FOMOCO) to get it out. The bottom of the box will have a metal sleeve with a rubber sleeve liner that connects drain port of box to the low post on block. This lower one will almost assuredly be cruddy and at least partly blocked.
wsmuller
Post by wsmuller »
Ok. At first, I wasn't sure if this was something to do now or when I replace the system. Thanks for the help. I'll post the results when I get it done -- hopefully next weekend.
mikealder
Year and Model: V70 2000
Been thanked: 13 times
Post by mikealder »
Best way to check the lower PCV port is clear is to attach a length of 5/8" dia heater hose to it then try to blow through it, if you can hear bubbling from the sump and can blow through it then it is clear, if you can't blow through it then it is still blocked. The port goes all the way to the bottom of the sump before turning upwards for an inch or two where it releases the PCV oil back in to the sump - Mike
wsmuller
Post by wsmuller »
Is there any way to check this without removing the intake manifold? Reason I ask is if it is clear, I could simply replace the broken hose instead of the whole PCV system. Or should I replace the whole system even if it is clear?
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
Not really
Replace the hose and do a breather test
jimmy57
Post by jimmy57 »
How many miles on the car and how clean is the oil filler cap area (the grate thing)?
If the crankcase vent system is not blocked at this time then the hose is all you have to do to make the car useable without setting codes for the vent system leakage. The hose being broken can lead to fuel trim out of range codes.
The breather test can be as simple as rubber glove sealed over dipstick tube while it idles. If it ok the glow might faintly inflate. if it pops, that ain't good.
wsmuller
Post by wsmuller »
It has 145k miles. The oil filler cap area is relatively clean. I bought the car from a dealer, and it looked like they had cleaned the engine pretty well.
