I just recently started having a cooling issue where the gauge looks normal but randomly it will flutter and then go up in temp in between hot and the middle. But after a few seconds it goes back down to normal. This all happens most of the time while stopped. I hooked my ODB-II up and saw that it's reading anywhere from 195 - 235 degrees. The cooling fan does turn on but only for a few seconds at a time when the ac compressor kicks on. There are sometimes where it will run for a few min but it's rare.
I knew it had the original thermostat and temp sensor so I did a flush and replaced the thermostat and temp sensor. I am still getting the same issues. Any ideas?
94 850 Turbo - Cooling issues RESOLVED, fan relay
- Year and Model: Many Volvos
- Been thanked: 76 times
A bad fan relay comes to mind.
The fan should be on full time when the AC compressor is running. You can test the fan relay by alternately grounding the relay pins associated with the Yellow wire and the Yellow/White wire on the center connector one at a time. The fan should toggle between both speeds if the relay is functioning properly. If the low speed side of the fan isn't working that would account for your temperature swings.
zero324
- Year and Model: 1994 850 Turbo Wagon
So I checked the relay and it was toast. So I went and got a new one. Right away the fan started working normally.
The issues that I have noticed and I dunno if this is normal or not. When I am driving and I hit the throttle any like to speed up I notice my temp via my ODB-II goes up. The needle stays in the center but my temp reads around 220 at times but as soon as i'm off the throttle and cruising it goes down under 210 and stays in the 190's in traffic.
Is that normal?
Is that normal?
- Has thanked: 1613 times
- Been thanked: 4078 times
Boiling point of 50-50 coolant under 1 bar pressure is about 245 F.
220F is fine.
220F is fine.
- 747 Views
Last post by tryingbe
- 1217 Views
- 928 Views
- 1408 Views
Last post by Biovince49
- 1742 Views
Last post by Ozark Lee
