1999 S70 Timing belt noise RESOLVED bad New part!
waynej
Year and Model: 1999 S70
Post by waynej »
Bought a used S 70 about a year ago. No record of when the timing belt had been replaced so I recently replaced belt, tensioner, idler, etc.
Now getting a low pitched whine from the engine. Started soon after the the belt change as a very faint sound that went on and off at idle and only after the car had been driven for 20+ minutes.
Now after a few thousand miles it is on all the time and is loud enough to hear while driving slow with windows down.
Seems to be coming from inside the timing belt housing. Just to make sure i checked everything on the serp belt with a stethoscope and all sounds OK.
Any ideas?
waynej
99 S70
96 854
87 245 wife's car
94 850 sons car
94 850 2nd sons car
Previous Volvos
93 850
87 744
85 244
82 244
80 244
78 244
78 245
76 265
71 P1800
71 142
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
If the belt and tensioner were installed properly it could be the idler pulley which I'll bet you didn't change
waynej
Post by waynej »
I did. Replaced everything. Trying to figure which is bad so I can order it and have it here before I tear it apart, need the car daily.
waynej
99 S70
96 854
87 245 wife's car
94 850 sons car
94 850 2nd sons car
Previous Volvos
93 850
87 744
85 244
82 244
80 244
78 244
78 245
76 265
71 P1800
71 142
Has thanked: 1611 times
Been thanked: 4075 times
You should be able to isolate it with the stethoscope trick - are you saying you cant hear the whine this way? How about power steering pump, alternator, water pump, AC compressor?
Idler pulley on the serpentine belt perhaps?
waynej
Post by waynej »
Thanks guys, finally got time to pull the cover and check with stethoscope. It was a defective idler pulley. FCP is replacing it but I have to pay shipping both ways.
waynej
99 S70
96 854
87 245 wife's car
94 850 sons car
94 850 2nd sons car
Previous Volvos
93 850
87 744
85 244
82 244
80 244
78 244
78 245
76 265
71 P1800
71 142
precopster
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
For the record was it a INA idler pulley or the GMB ?
