ugh. any idea how difficult a job this is?
at least it's not the rack. not yet, that is.
I love the car and JUST put it back on the road after about a 1.5yr layup.
1996 960 - $650 to repair PS hose
precopster
- Year and Model: Lots
- Been thanked: 128 times
That's a ridiculous quote from the face of it.
The hose itself is around $180 NEW.
Are you happy to DIY this repair? If so you could purchase some pipe spanners and still have change left over.
Are you happy to perform the work yourself?
JDS60R
- Been thanked: 3 times
If its just the line ( rubber part) that is leaking then remove it and take it to a hydraulics shop. High pressure hose and a few crimps will save you a ton.
Retired
precopster
High pressure hose (9191450) costs $162 at Volvo Wholesale Parts
Low pressure hose (980477) costs $11 at Volvo Wholesale Parts
2 X new crush washers (provide dealer with VIN for correct items) are about $4
Labour for BOTH hoses R & I is 40 minutes
960, S.V90 Repair Times.pdf- (5.96 MiB) Downloaded 123 times
precopster
The hose for $162 above includes everything from the PS pump to the rack including the rigid section
There is no cooling of the PS system.
- sanfelice
- Year and Model: 00 VR;04 XC70;97 965
http://www.volvopartswebstore.com/image ... -70478.jpg
#15
i think this may be what he was referring to.
I have tackled things probably as difficult (or more so, if the book has it at 40m...).
tx
#15
tx
precopster
Apologies yes I can see that it's called a cooling coil. 9169584 costs $77 new from site sponsor.
Cooling coil isn't mentioned in repair times PDF. Perhaps get a quote to fit it.
