I have a question...
It appears my evaporator cover is not water proof.
A part of the condensation will leak through the evaporator cover.
First thing would be my drain should be stuck, but this is working good, since a lot of water drains down through the evaporator drain.
Also my pollen filter is completely dry, so nothing is coming from the outside
So after further investigation I saw that the lowest screw of the evaporator cover is not that tighten anymore.
I think this is my problem.
Is there somebody else who had this problem, or somebody else has a solution how you can fix this the best way?
Because a lot of condensation is coming throug the evaporator cover on long distances.
Thanks in advance
On the picture:
Red circle = the screw that will not thighten anymore
Green stripe = point where condensation comes throug.
