This is another tidbit from ipdusa site:
Sunday, July 17, 2011 - MARTYN P ROWSON
I have worked in Volvo dealers for the passed 18 years and experienced a lot of customers with 850, C,S,V70 with 10valve and 20 valve engines engine light on. Fault codes say MAF,boost pressure sensor,baro sensor and long term fuel trim faults. 90 of the time the fault is a dirt or loose earth point under the right head lamp. I remove the lamp, move the front panel to access the earth terminal, grind away the paint and replace the bolt. Also found it improved startying and performance.
http://www.ipdusa.com/blogs/105/top-10- ... v70-models
I'm not aware of this ground. Does anybody have additional information?
Volvo 850''s: evil ground causing problems?
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
I didn't know there was one over there, but my guess is that it's the major ground point for the entire ECU box.
Good to know! Thanks!
'98 S70 T5
2016 Chevy Cruze Premier
northernlights
- Year and Model: 850 Turbo 1994
- Location: Florida and/or Raleigh NC, depending on the day
- Been thanked: 8 times
I suspected a grounding problem on this post, although it may not have been the case. This was for a 99 V70, but there was a main ground point near the right side headlight.
https://www.matthewsvolvosite.com/forums/viewtopic.php?t=52657#p263626
From what I've seen, auto sensors are very sensitive to bad grounds because most of the signals are voltage based. Bad grounds mess up the signals as they 'use up' some of the voltage.
- 1147 Views
Last post by oragex
- 571 Views
- 572 Views
Last post by JimBee
- 2295 Views
Last post by RickHaleParker
- 18 Replies
- 3138 Views
