98 V70 GLT do I truly need to get under the car for PCV?
taupehat
Year and Model: V70, 1998
Post by taupehat »
Just got done watching the vid at FCP on the PCV fix and never once did the guy get under the car. Went out to mine and felt around, was able to easily get to the bottom two bolts for the intake.
So to those of you who have done these (the more specific to the model year the better), what were your experiences? Were you able to get those bolts off and on again from the top of the car or was it a huge and avoidable hassle?
Reason I ask: the work I can do at home is limited to not raising the car up due to both the slope of the driveway and my rental agreement. And I don't have another place I can do work at.
Matty Moo
Year and Model: 850, 1996
Has thanked: 1 time
Been thanked: 30 times
Post by Matty Moo »
I've never gone under the car to do it.
You can hit all the bolts using an extension, I always use a u-joint on a couple and an actual wrench on the lower bolt on the driver's side.
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
wheelsup
Has thanked: 15 times
Been thanked: 20 times
Post by wheelsup »
I did mine in my garage on the ground.
Seriously consider a locking extension set, I lost 3 10(?)mm sockets (and bolts) as they fell off and down trying to get the intake manifold bolts out...
A magnet extension tool also is nice...
Year and Model: Many Volvos
Been thanked: 75 times
Post by Ozark Lee »
The only thing I go underneath for is to get the support bracket bolt off of the intake manifold. It can be done from the top but I find it to be easier from the bottom with a couple of long extensions. Same thing for the dipstick tube mount.
Has thanked: 292 times
Been thanked: 765 times
Post by erikv11 »
Just finished a PCV job on a 98 V70 GLT. I raise the car because I don't like bending over, but echo what everyone else posted: no need to get under the car if you've got a few specialty tools and and don't mind working blind on a couple bolts under the manifold.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 19 times
Post by jblackburn »
No. With a ratcheting closed-end wrench, you can pretty easily get to the bolt under the intake manifold.
'98 S70 T5
2016 Chevy Cruze Premier
taupehat
Post by taupehat »
jblackburn wrote:No. With a ratcheting closed-end wrench, you can pretty easily get to the bolt under the intake manifold.
12mm or 10?
jblackburn
12mm or 10?
12.
'98 S70 T5
Klausc
Year and Model: 1995 855 Turbo
Has thanked: 5 times
Been thanked: 15 times
Post by Klausc »
When I did my 98 I should have raised the front end, just to save my back from bending over. The only time I got under the car was to look for dropped nuts!
Suggestion: remove the engine fan, easy to do with only 2 torx screws and gives you more room.
Suggestion: when putting the manifold support bracket back on, loosly attach the bottom bolt. Then after the manifold is in place attach the top support bolt and reach down and tighten the bottom bolt. I used a 1/4 ratchet for both, small enough to get in there.
Count on 4-6 hours total time.
Klaus
obayha
Year and Model: V70 1999 Base
Been thanked: 2 times
Post by obayha »
2x on this tool. I got one that has the swivel end and worked great.
1998 V70 T5 331,000 :( Her last day was on 3 cylinders.
New to me 1999 V70 NA 163,000 Now at 217,000
2006 V70 2.5T in driveway (WIFE'S)
1982 Toyota FJ40 Land Cruiser
