00 s80 grinding/noise at 30 - 60 mph
Between 30 and 60 mph I get a slight grinding through the steering wheel, any tips for narrowing down axle vs wheel bearing? There's no play in the front wheels top to bottom so I am hesitant to throw a new wheel bearing at it. The noise goes away when I am turning right and I have no other symptoms of a bad axle (no clicking noises, no leaking grease).
I had slightly similar problem.
When I was going at about 60-70 mph I would hear some soft of HOUL noise. But when I turned wheel to the left it would stop. Went to a local mechanic and they listened to it through a stethoscope.
I just decided to change the bearing and I was right. It was my left bearing.
Maybe yours worn out already and makes grinding noise.
Try that option.
Good luck!
Try that option.
Good luck!
chrism
- Year and Model: S80 / 2005
- Has thanked: 7 times
- Been thanked: 89 times
Check out Youtube for videos on changing axles. Even if it's not a Volvo, the procedure is pretty much the same. For instance I did my V70 and my daughter's Hyundai - no big difference between the two.
- 856 Views
Last post by Cees Klumper
- 2231 Views
Last post by SuperHerman
- 1155 Views
Last post by kevplank
- 1400 Views
Last post by hotwheelsndeals
- 11 Replies
- 2437 Views
Last post by Ozark Lee
