Hi All,
I recently purchased a 1997 S70 that has only 110,000 kilometers on the clock. The car is in great shape but i've noticed that it shifts hard between first and second, and second and third gears. Some of the time the shift is smooth, but is usually fairly hard.
I have a 1998 V70 with the same gearbox and double the kilometers that has butter smooth shifts, so I'm wondering what the difference is with my S70?
The fluid looks to be in good condition and is still red in colour. Just wondering if anyone has any pointers on what I should look for?
I've noticed that the car has had had the gearbox oil changed in the past by a non-volvo mechanic, but I imagine that they wouldn't of used the wrong oil given that it only requires dexron.
Any help or pointers to help me diagnose the problem would be much appreciated.
1997 S70 Hard Shifting transmission 50-42 - low kilometers
JDS60R
- Been thanked: 3 times
Is it a turbo?
If not check:
1. the fluid level.
2. If it shifts differently with the AC off vs on
3. if the hot air door in the air box is stuck on hot position as air box thermostat has failed .
I like to do a fluid change when I get a new addition to the fleet so I know when it was changed and what was used.
If not check:
1. the fluid level.
Retired
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
Pretty much the same but do try to figure out if you can solve the problem by process of elimination. Just did a drain and fill on a friend's Sienna last month while visiting him in NC. Used Lucas TransFluid from AutoZone and it greatly reduced the bearing groaning problem at certain RPM'S during acceleration. It was at his mechanic for this issue not too long again so the fluid looked good. Not all Tranfluid's, especially DEX are made the same. Tried a bunch as I use to have a 323 and Grand Voyager which are notorious for Tranny issues.
1) Adjust fluid level accordingly regardless of it's condition
2) If improvement do a drain and fill with Lucas or a Synthetic to see if there is further improvement
3) If not entirely gone try Lucas or K&S Tranny Slippage Fix
Depending on your results along the steps you can have a good idea what is causing the problem
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
When we got our S70 it was shifting hard. I replaced the lower torque mount and ALL of the hard shifting went away.
Thanks for the feedback.
I should of mentioned that this is a 24v non-turbo s70.
I'll start the process of elimination, but I have noticed that the hard shift still occurs when the air conditioner is on. The fluid level is ok too.
I never would of though thought to check out the hot air flap, but I'll check it out!
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
Check out the lower engine and transmission mounts.
If your car is like mine, it revs to the moon with the AC on, which will result in a pretty hard shift at 3500-4000 RPM.
If all else fails, changing out the DexIII for Mobil-1 ATF was a pricey solution to get extremely smooth shifts.
'98 S70 T5
2016 Chevy Cruze Premier
A long overdue update…
I’ve changed the oil in my S70 (and ensured that it is at the correct level) but the hard shift persists. I’ve used the same type of oil that I use my V70 that has the butter smooth shifts.
I’ve checked the hot air door on the breather box, and the hard shifting occurs regardless if the a/c is on or off. The transmission mount looks to be fine too with no play.
Any other ideas on what the problem might be?
- 465 Views
Last post by LOB
- 934 Views
Last post by SuperHerman
- 770 Views
Last post by rickbrk
- 621 Views
Last post by tardcart
- 14 Replies
- 5969 Views
Last post by stoutlogic
