I've just recently picked up a parts car. I was just removing the sump for a fellow member on the site, and this is what greeted me as the sump came off the engine:
https://skydrive.live.com/redir?resid=B ... rlImRNmjzM
https://skydrive.live.com/redir?resid=B ... k6F6itBjwg
https://skydrive.live.com/redir?resid=B ... ZrTld1Rq5w
check this out! Metal in sump
difflock54
- Year and Model: V40 Nordic 2002
- Has thanked: 7 times
- Been thanked: 2 times
Look like ground up bearing shells.
shanegtr
- Year and Model: 1999 V40 2.0T
Not seized as far as I know. Although there was/is a healthy dose of oil in the coolant. Looked nearly identical to drill swarf and there was bugger all oil stuck to it. Almost like the sump had been off and it was put there - put the sump hadn't been off. If Mel sees this post Im sure she'll comment on how much metal was in there.sailtough wrote:Yikes, did the engine turn over or was it seized?
When I pull the gearbox out of it I might throw the remains of the engine onto my stand and strip the bottom end and see if I can find a sourcedifflock54 wrote:Look like ground up bearing shells.
