2007 C30 Steering Coupler stiff
Help, Advice, Owners' Discussion and DIY Tutorials devoted to the second generation C70, S40 and V50 Volvos -- awkwardly model year 2004 ½ onwards -- plus where to go for advice and discussion on Volvo's sporty C30 Coupe powered by Volvo's ubiquitous inline 5-cylinder power plant.
pbanyard
Year and Model: c30 2007
Post by pbanyard »
The steering is stiff, especially going straight. My mechanic says I need a new steering coupler which is only comes as part of the complete steering column. The cost is more than $1,000.00 for the part alone. Does anyone know of any alternatives to buying a complete steering column?
thanks
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
Is it the one right on top of the steering rack? Maybe you can disconnect the steering shaft under the dash (on bolt), then remove the dust boot on the floor and you get access to it. With the shaft disconnected, you will be able to swing the coupler all sides while shooting some Lubricating Liquid Wrench (lubricating one, not the penetrating one). Once loosen up, spread with grease.
