99' s70 abs& brake light & loss of speedo
bsbartow
Post by bsbartow »
also have problems w/ets
cdes are p0722, p1017, p1059,p1021, p0600
I've changed speed sensor, ref. sensor , weathr switch& neutral saftey switch
Jot
Year and Model: C30 2010
Post by Jot »
The codes are list in "Volvo repair Database" remember to type a "P" before the number
Guest
Post by Guest »
p1017 p1059 p1021 all say unknown
p0600 serial communicationlink malfunction
cmarti2
Post by cmarti2 »
I have the same problem, except that it intermitting (sp?). It nevers last more than 2 mins. Has anyone seen this? and what's the fix?
Thanks
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
Well, I don't know all of the codes but your title indicates every sign of an ABS sensor going bad. Look for a guy called Victor Rocha here and on other Volvo boards (I believe he's a member here too) such as www.brickboard.com and www.swedespeed.com and email him with the same thing you posted here. He is good about answering his emails and he'll give you the low down- such a nice guy! Victor rebuilds ABS modules for $140 shipping included. He tells you how to get it off and back on your car yourself so you can send it to him and will even supply the torx socket you'll need to do this if necessary. He repaired mine and I've had no issue since then. The Brake light and no speedo is a definite sign of a bad ABS module. Good luck.
