I replaced the rack and pinion and tie rod ends, made in Germany. They were very hard to pivot. After about a month the rack started leaking again (from Rack Doctor). It's 6mo + and the tie rods are still very stiff= need vice grips to rotate. I'm wondering if this caused the rack to wear out because it is such a load on the rack. I've never replaced the tie rods before but I can't imagine them being so stiff. Maybe they forgot the grease? Ever heard of this before?
Bob
New Tie Rod ends too tight?
Matty Moo
- Year and Model: 850, 1996
- Has thanked: 1 time
- Been thanked: 30 times
Mine are still relatively tight from when I first installed them last year. It's highly unlikely they had anything to do with the rack leaking.
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
The tie rod has two joints: one at the wheel and one at the steering rack. If they don't rotate, it might be the joint at the steering rack (inside the steering boots).
I would remove the boots on both sides of the rack - they are kept with plastic ties - and have a look at the exposed rack rods. They must be shiny and exempt of rust. Move wheels from side to side. If they are rusted, this eats the seals when you turn the steering wheel. Also, check the joint in the tie rods, I suspect is also rusted and seized, disconnect the tie rods (on the wheel side) and spray the joint with Liquid Wrench Lube (blue bottle).
The rack was just rebuilt and I put it in- the inner joints were good. The outer ends were very stiff.
I should add that I put an in-line filter in the return line. I'm starting to wonder if that got plugged causing a rack leak, which appears to be leaking out of the pinion shaft cover at the bottom. This could be coming from the left rack seal too I guess.
- oragex
The tie rods show be quite easy to turn with a key.. Sometimes also the rack rubber could be quite tight but nothing to have it turned with a wise grip. Which end do you think it's stiff, the one to the wheel or the inner tie rod?
- oragex
When you say it's stiff you mean you have to force on the key to turn it? It shouldn't be hard to turn with a key. Maybe that particular after market parts are build that way. I guess it forces more on the steering pump, less on the seals because the lever is not so long.
- 2681 Views
Last post by manovlov
- 557 Views
Last post by dairyqueen814
- 1384 Views
Last post by E Showell
- 721 Views
Last post by vtl
- 12 Replies
- 2969 Views
Last post by erikv11
