1997 850 GLT - Dual climate passenger side fail
bjmcc1984
Year and Model: 97 850 GLT/2006 XC70
Post by bjmcc1984 »
Does anyone know why my passenger side temperature dial no longer changes the passenger side from hot to cool?
Occasionally, it will "reset" after a few drive cycles but it doesn't seem to be happening at any specific point.
Thanks
Year and Model: 2004 V70 2.5T
Been thanked: 468 times
Post by cn90 »
Do you have ECC (Electronic Control Climate)?
If so, then search forum for "damper motor".
bjmcc1984
Post by bjmcc1984 »
I'm not sure if I do but that sounds like a likely culprit
Thanks
jreed
Has thanked: 352 times
Been thanked: 192 times
Post by jreed »
I did a short write up on how to diagnose, remove and clean up a damper motor. You could also just remove and replace a bad damper with a new/used one. Cleaning up the old damper and reinstalling it fixed my problem with lack of temperature control in the ECC on my '97 855 GLT:
https://www.matthewsvolvosite.com/forums ... =1&t=50525
