I need help locating vacuum leak. Any suggestions?
Help finding Vacuum Leak 93 850
I am getting codes 113 and 232 from (A2) socket on my 93 850. Replaced IAC Valve, TPS and O2 sensor.
Rosel
- Has thanked: 2664 times
- Been thanked: 1256 times
Check the small-diameter white tubes in the engine bay. There's one that runs across the top in the front. Others elsewhere... can't remember off the top of my head. Also check their elbows for cracks.
White850Turbo:
"The best way to find the leak is with an unlit propane torch; when you get near the leak, the idle speed will rise."
White850Turbo:
Found the leak. It's in between thermostat and fuel injector #1. Way below. I can't reach it with my bare hands. I can't even see all the way through. I used a carb cleaner and sprayed down there and the engine rev'd up.
This looks like a big job to dismantle and put back. Any suggestions?
Rosel
lh
check out http://www.volvospeed.com/volvo_performance.php
there is a section on vacuum lines in repairs and maintenence that is helpfull
- 2446 Views
Last post by gordo850turbo
- 41 Replies
- 787 Views
Last post by BeerDeer
