2001 V40 Trailer Wiring
1996 - 2004 S40
1996 - 2004 V40
ozbrick
Year and Model: V40 2001
Post by ozbrick »
Just attached a tow-bar (trailer hitch in US). This presented no problem till I got to the electrical stage. The tow-bar came with a wiring harness from an S40 and the plugs don't match! I found a four pin female connector behind the lights at the back left pillar of the car which I believe is for linking the trailer wiring. The four wires are black, brown, yellow and yellow with red stripe. This I have replaced with a standard crimp on 4 wire female connector. There is also an uncut loop of 3 wires in the same area which are possibly related (red, blue, and purple with white stripe). The harness wires are connected to a plug on the tow-bar according to the Australian standard large 7-pin wiring code.
Then I put temporary spade connectors on the wires that I need for left turn indicator (yellow), right turn indicator (green), stop light (red) and tail light (brown). The white earth return wire was connected to earth on the vehicle body. Test time and no combination gave good results with indicators. The tail light when connected to the yellow/red wire is on with or without ignition. The stop light works as it should!.
Does anyone have a wiring diagram for a V40? (VIN YV1VW17K91F670274 if it helps)
Thanks
Dave
96VolvoS70
Year and Model: 1996 S70
Post by 96VolvoS70 »
This isn't a wiring diagram for your particular Volvo but it could possibly help with your wiring questions.
http://www.hitchanything.com/trailer-wi ... guide.html
mikealder
Year and Model: V70 2000
Been thanked: 13 times
Post by mikealder »
You find the wiring diagram you need by clicking Here - Mike
