The mileage is around 170k, was running fine until we did a quasi-tuneup.
The spark plugs, copper Bosch, were replaced in summer and running fine. I got 27-28 MPG on highway.
I replaced the distributor cap, rotor, Bosch from IPD. After quasi-tuneup, I drove on highway and felt it's normal. After an hour, around 70 miles, I felt sudden shaking on a long uphill road. My first guess was flat tire. After pulled over, the tires were fine. The car had a rough idle. I pulled the code from engine.
543 Misfire – at least one cylinder.
453 Misfire – #3 cylinder.
545 Misfire – at least one cylinder/catalytic converter damage.
451 Misfire – #1 cylinder.
551 Misfire – #1 cylinder/catalytic converter damage.
553 Misfire – #3 cylinder/catalytic converter damage.
544 Misfire – more than one cylinder/catalytic converter damage.
542 Misfire – more than one cylinder.
I bought a new set of wires, bosch(only available at the moment), and the problems remain the same.
I disconnect the cat from the exhaust and the car still powerless. I suspect the cat is gone, but could not figure out the main reason for the misfire.
Please share your ideas and I want to get my old volvo back on road. Thank you.
1995 850 Turbo Wagon misfire
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Start with the basics. If you have a multiple misfire, my guess would be that you have a fuel delivery problem or coil issue. Is the spark bright?
- rspi
Contact rspi..
Oh, check to make sure you don't have any air leaks in the intake tubes. Happens a lot after people put things back together.
- rspi
Contact rspi..
Because something went wrong. Did an intake tube come loose?
- 19 Replies
- 9282 Views
Last post by Barledge
- 1289 Views
Last post by southofmotown
