I can't get retaining ring on fuel pump to budge with drift or oil filter plyers. Now what do I try?
1993 Volvo 850 GLT
88,000 miles
No history before 2012, just tuned up.
Fuel Pump Replacement
- kcodyjr
- Has thanked: 17 times
- Been thanked: 23 times
Squirt some PB Blaster into it?
5 others that came and went
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
They sell the wrench/adapter at most auto parts stores. The video below might help.
- rspi
Contact rspi..
QuirkySwede
- Been thanked: 12 times
Do not use a drift or pliers. Go to Autozone with $100 cash and loan:
OEM/Fuel pump replacement kit, Part Number: 27160
http://www.autozone.com/autozone/access ... 05758_0_0_
You'll use the tool on the bottom to hook under and pull up to remove the fuel connections (if you're pulling hard, the tool isn't under the release part), and the part on the right to remove the ring. By paying cash, you'll get your money back as soon as you return the tool (mind the time limit) versus using a card which can take days to be credited back to your account.
And if you don't have a verifiable record of it being done, make sure you replace that timing belt, idler, and tensioner pronto! Whether to replace the water pump at a 70k mile interval or 140k is debated.
- Been thanked: 504 times
I used Sears Craftsman Oil Filter Tool:
http://www.sears.com/plews-oil-filter-w ... 6142951201
Crank only enough to "bite" the Plastic Ring. Then twist it CCW to remove it.
I wrote all the tricks below:
DIY: 1998 S70 Fuel Pump RUBBER SEAL
https://www.matthewsvolvosite.com/forums ... hp?t=60329
Below is a photo showing the tool in action:
While there, you may as well take care of:
- EVAP Hose
- Plug the area where the wiring enters the Plastic Top Cover. I used Butyl Rope to plug it:
https://www.matthewsvolvosite.com/forums ... hp?t=60269
https://www.matthewsvolvosite.com/forums ... hp?t=24518
- EVAP Hose
- 42 Replies
- 12278 Views
Last post by Maestrours
- 5158 Views
Last post by wizechatmgr
- 16602 Views
Last post by Richard99
- 2224 Views
Last post by precopster
- 575 Views
Last post by alschnertz
