2005 S80 exhaust valve control solenoid circuit
Everything on the Volvo S80. Sometimes called an "executive car", the S80 was Volvo's top-of-the-line passenger car. P2 platform.
bforte
Year and Model: s70 1998
Post by bforte »
I need some help fast! Wife called telling me her car sounded funny, (2005 Volvo s80 AWD). I checked it out when she got it home and found no oil in it, barely registering on the dip stick.... I got a P0027 when I dumped the codes, " exhaust valve control solenoid circuit range performance bank 1). Anyhow, I poked and prodded and also found that the PCV tube was broken in 5 pieces, (original Volvo hard plastic), this might account for the oil being missing. The car has only 109,000 miles on it and has never burned oil. There is also no sign of oil underneath it. Hmmmm.... I replaced the PCV tube removed cleaned and re-installed the Exhaust and Intake solenoids. Better but still throwing codes. I then replaced the exhaust solenoid but when warmed up almost sounds like a diesel. I also replaced the timing belt, water pump, timing belt idler pulley as well as the tensioner, but that was nearly a thousand miles ago... I have checked the timing marks to ensure no slipping took place and all looks fine. Anyone have any suggestions?
05Volvos80
Year and Model: 2005 S80
Post by 05Volvos80 »
Hello. Wondering if you ever figured out what this issue was. I'm having the same issue with my 05 S80 - missing oil, sounds like a diesel, solenoid replaced... Thanks!
