1999 V70 Shifter Up Arrow Problem
DavidsVolvo
- Year and Model: 1998 V70, 1999V70XC,
My automatic non-turbo wagon has an up arrow and shift issue. The transmission shifts fine, but the up arrow light comes on blinking when in drive and the car seems to be starting out in a higher gear, Not 1st. I can drive the car manually (1,2,3,4...). Is this an electrical / switch issue or is the tranny toast? Does the tranny need fluid changing or is it low? Is this a safe mode for the tranny? Help!
- kcodyjr
- Has thanked: 17 times
- Been thanked: 23 times
If it shifts normally and smoothly when you do it manually, stays in gear and doesn't slip or anything, then you don't have an internal mechanical problem. There isn't much information here, but I'd suspect wiring harness first. Maybe the TCM shook loose when you went over a bump?
Flashing up arrow means stop driving it. Like any such idiot light, it's programmed to be a bit conservative. If you're on top of shifting promptly, I don't see a likelihood of damage, but don't quote me on that.
If you hear any odd noises, especially grinding or scraping noises, pull the **** over and get a tow.
5 others that came and went
DavidsVolvo
Thanks guys. I drive the car on the highway last night 150 miles. The car runs great in top gear. The blinking light seems come on intermittently on the highway. The car is definitely stuck in a safe gear now no matter where the shift is and does not seem to shift anymore. I'll get out the analyzer and check codes.
DavidsVolvo
I checked the engine and TCM codes...there are none. The engine is running great, but the tranny is in the safe mode with the blinking up arrow. I've changed the tranny fluid once (draining). I'll drive it and change it again hoping that the safe mode goes away. Should I crack open the solenoid case and look at the screen? Any other suggestions? By the way, the code reader does not allow me to reset anything on the TCM
Matty Moo
- Year and Model: 850, 1996
- Has thanked: 1 time
- Been thanked: 30 times
What reader are you using? If that light is blinking there are codes.
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
precopster
- Year and Model: Lots
- Been thanked: 128 times
It would be good if moderators could merge both the topics you have running on this problem.
As above you really need to have the codes properly read before you act. There is no screen behind the solenoid cover; in fact there's no screen which is serviceable from underneath either.
DavidsVolvo
Thanks...I am trying to determine if the tranny is toast before I junk it or spend $$ on fixing it. I am grateful that guys are instructing me to get the codes. I don't know if my analyzer can get the codes and reset the TCM as it is real strange that the limp mode and blinking up arrow are there with no codes.
I am using an AUTEL MaxiDiag Pro MD801 Two Questions...
If the Limp and blinking are present...there has to be codes. Correct?
Does the limp mode need to be reset through the OBDII port even though the incident has been resolved?
Matty Moo
The MD801 reads tranny codes.
Select Volvo>Model>Year>TCM. Don't select OBDII which is at the top.
2000 s70 GLT
2014 Ram
DavidsVolvo
Thanks for helping me out on this, that's what Autel said too. I think Tranny issues are the hardest to solve.
Making this simple...If this Autel analyzer is not seeing the tranny (TCM selection) at all on the Volvo-1999-V70-AW50-42 selection, then there is mot likely something wrong with a connection, the TCM or a harness which could be causing the "limp mode". Does anyone agree?
- 7876 Views
Last post by oragex
- 493 Views
Last post by Cincyken
- 1250 Views
Last post by 93Regina
- 1894 Views
Last post by 69142S
- 1272 Views
Last post by jose456891
