1999 V70 XC Replacing auto trans shifter knob
jeff-p
- Year and Model: v70 awd, 1999
Is replacing the automatic trans. shifter knob simply a matter of yanking the old one off and sliding the new one on? The shifter knob lock button stays depressed allowing the shifter to bumped out of gear. I would like to replace the whole knob/button assy. even though a button replacement kit is available. Any experience with this procedure? Thanx, Jeff
- Year and Model: Many Volvos
- Been thanked: 76 times
Pull up, really hard, and try not to break your nose or knock the rear view mirror off when it comes loose. I normally set the parking brake and put it in neutral since it gives me a better pulling angle.
The new one just pushes on and snaps in place. You will need to pull the boot back up and get it to snap in place as well but that is painless.
- dosbricks
- Year and Model: '96 855, '98 S70
- Been thanked: 4 times
"simply a matter of yanking the old one off...."
Yanking--yes. Simple--not so much.
Being old and having a bad back, I decided to pry it off using an open-end wrench with a wood fulcrum next to the console and a pry bar cheater in the closed end. I gradually increased the leverage until it came off alright....like a rocket, which cannonballed into the headliner. Amazingly, there was no damage that I could detect. Next time I'll have my wife hold the laundry basket over it
Jono51
- Year and Model: V70XC, 1999
I used the button replacement kit from IPD - found it pretty easy to fit. Don't see why you'd want to replace the whole knob unless you happen to have a good one that you've acquired for free?
If God had meant cars to have fuel injection, he never would have given us the SU carburetter
I replaced the button on mine recently but i think the only problem was that the little spring had shifted position. The spring should be placed so that it resists the button being pushed in. I tried to take a picture of the correct position but could not get a good one.
1998 Volvo V70 AWD 165000-R muffler, HD endlinks, boost gauge
2008 Ford Fusion AWD 107000
2000 Ford Ranger 4wd 172000
1991 Toyota Camry 160000#1
Previous: 1982 Volvo DL (240) 160000
1998 Tacoma, Fords (6), Dodge, Montero,
GTO, Sunbeam Alpine, VW Dasher
- 7886 Views
Last post by oragex
- 1354 Views
- 3823 Views
Last post by Deltaromeopapa
- 733 Views
Last post by lummert
- 946 Views
Last post by amblerman
