2000 S80 T6 - What is this (valve?) called?
Everything on the Volvo S80. Sometimes called an "executive car", the S80 was Volvo's top-of-the-line passenger car. P2 platform.
Bluevanacd2005
Year and Model: 1983 760
Post by Bluevanacd2005 »
I have what I think to be a valve dripping oil on top of my engine... it is between the inlet to the turbos and air filter, and comes from the oil seperator box. I attached a picture of it (microsoft word format), but cannot figure out what its actually called.
Thanks,
Spenser
Valve.docx
(597.74 KiB) Downloaded 82 times
I like curves on my women, not my cars
jimmy57
Been thanked: 320 times
Post by jimmy57 »
It is a heated nipple where the oil containing vapor hose meets the incoming fresh air hose from air cleaner to turbos.
More than likely the grommet where nipple inserts into turbo air pipe is the leak. That connector hose from metal vapor pipe to nipple has the split and that could contribute also.
Bluevanacd2005
Oh ok thanks. Thats interesting. I wonder if a burned out heating element would throw the CEL? Or what 'bad' things would happen to the oil vapors if they didn't get heated?
jimmy57
Post by jimmy57 »
There is no diagnostics on that heater. It is there to assure that in subfreezing temps that the moist vapors from crankcase don't freeze and block the venting.
