2004 V70 2.5T Very nice...no window washer
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
ScaleAutoArt
Year and Model: 1998 V70
Post by ScaleAutoArt »
Great car, low miles [98K], very clean and much more power then my 98 NA.
Question...I have no window washer...pump doesn't run. Best way to troubleshoot?
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
Panel fuse.
ScaleAutoArt
Not the fuses or relay....anyone tell me where the pump is so I can test it?
DGM
Year and Model: V70 2.4i 2005
Been thanked: 3 times
Post by DGM »
ScaleAutoArt wrote:Not the fuses or relay....anyone tell me where the pump is so I can test it?
The pump (6/2) is under the tank on the right front corner. Fuse 11B/16 and relay FMI3 (2/92) are located in the engine compartment. The pump is shared by the headlights and the windshield washers. I found this for your car on the web. In the diagram, L.E indicates late edition and E.E early edition. If you remove FMI3 and jump pins 1(86) and 3(30) the pump should run.
Access is limited and sometimes the front bumber must be removed. Here is the procedure to follow;
https://www.matthewsvolvosite.com/forums ... =9&t=48672
Have fun,
V70 2005 2.4i 195,000km, sold
S70 1998 T5 355,000km, sold
960 1994 80,000km, sold
760 1990 Turbo 265,000km, sold
