For some reason after driving the car around town for say 30-45 minutes, suddenly the car will just quit... Total ignition failure...even going down hill with key on and car in gear, it will not fire... Now if I cycle the ignition key to completely off position and then back to on, the engine fires right away and off I go... However often not for more than a couple minutes and it does it again....
Now if I stop the car, let it cool right off and say go and drive it again in an hour or so, it runs perfect for an extended time, but eventually will start acting up again with ignition failure. Anyone out there think they know what may be the problem?? Which electrical component shall I replace first?
Not sure if it is relevant, but the car never does it right after I start it, it always happens after she has warmed right up,,,, say 30 or more minutes into a drive. The temp gauge never goes out of range or anything....
Any hell would be awesome
, thanks so much in advance...
Tsebast.
And if I can't trouble shoot myself, with help from others, does anyone know a good volvo mechanic in vancouver canada I could use??
