OK..............I am at my wits end....I have read every no start forum article and traced everything and I am totally perplexed. I consider myself to be an expert back yard mechanic but this is really messing with me. It is a 1991 740 wagon with 149000 miles.....in magnificent shape. I bought it from a guy not running who, like myself had lost all patience with it.....It was running fine for his wife one day then ...bam...dead...he got it running for a couple blocks and then bam....dead again........here's the rundown:
1) Fuel pressure is great at 10 plus pounds
2) Spark to the plugs
3) relays good (tested)
4) IAC valve good (tested)
What next..........I am trying to figure out best way to test injection system.........
Thanks,
mojoe
1991 740 No start-up....Everything tried
mojoe28613
- Year and Model: 740 1991
mojoe28613
Yeah....my fuel pressure gauge didn't go any higher, but it pegged it HARD.......Fairly sure the fuel pressure is good.......new fuel pump was dropped in tank. I'm beginning to think along the lines of the ECU being bad.....
Thanks,
mojoe
Thanks,
mojoe
If you haven't fixed it yet.. I had the same problem. Found the RPM sensor bad... On top of the transmission bell housing.. blew me away. It would run for a while then quit.. Everything else was good..
Hope it helps...
Larry
Hope it helps...
Larry
mojoe28613
Well.......She's still sitting in the same spot in the shop.......I think I have finally figured it is something to do with the injectors.....How can I tell if they are pulsing when I'm trying to start the car......started to pull the fuel rail but seems like there would be an easier way....
Thanks,
joe
Thanks,
joe
Ethan Rode
- Year and Model: 960 1996
You could use a noid light to make sure that the injectors are getting signal from the ECU. I usually rest a long screwdriver against each injector, as a kind of stethoscope. That is more helpful in diagnosing power balance problems, though. It's unlikely that all the injectors are bad.
rgk
- Year and Model: Gray 88 245
- Has thanked: 1 time
You can rent a fuel pressure gauge from an auto parts store. If your gauge does not go above ten psi, then it is likely not a real fuel pressure gauge.
rgk -- was dickdeadly
mojoe28613
Yep......I tried the Radio suppression relay swap and nothing....
I did get it to bump fire on starter fluid........
One evening this week I am going to see if I can hear the injectors firing........
- regent
- Has thanked: 2 times
- Been thanked: 12 times
Have you physically checked the positive supply voltage to the injectors with a volt meter or test light?
You should see close to Battery voltage on all injectors with reference to negative/chassis (while the ingnition is turned on and the motor is still).
On a running engine, "pulsing" is done by switching the negative on/off.
The only way for all injectors to play "bad" is absence of +12 V.
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired
1987 340 DL - retired
2015 BMW 335i
- 18 Replies
- 5144 Views
Last post by difflock54
- 16 Replies
- 3627 Views
Last post by MadeInJapan
- 1057 Views
Last post by rice240
- 2062 Views
Last post by dougburgy
- 1781 Views
Last post by jreed
