'98 V70 Lights on Dash flicker w/ revs.
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 111 times
Post by E Showell »
I noticed at idle at a stoplight the other evening that the dash lights seemed to fade/increase in intensity in relation to engine idle. If the idle dipped a bit, the dash lights dimmed. If it came up, they brightened -- not talking huge variations in brightness. In fact, if you weren't looking for it specifically, you probably wouldn't even notice it. The idle wasn't fluctuating enought to even register significantly on the tac. I still have my original alternator at 263K miles. Are the fluctuating dash lights a precursor to alternator failure?
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
Has thanked: 292 times
Been thanked: 765 times
Post by erikv11 »
Flickering lights are are a classic sign of worn out brushes. You can change the VR in your car with the alternator in place, be sure to check the slip ring too, though. Several alternator posts today, check out the top of the forum.
I would also check the grounds and both ends of the positive cables.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
E Showell
Post by E Showell »
VR? I am assuming "voltage regulator"?
'95 855 auto (sold)
Post by erikv11 »
Yessir, voltage regulator.
Check this out too: https://www.matthewsvolvosite.com/forums ... =1&t=61610
'06 S60 R, 197k
Year and Model: 2004 V70 2.5T
Been thanked: 466 times
Post by cn90 »
Many many years ago, the VR is a separate component from the brushes.
Fast forward to the modern time (1990s --->), whenever the word "VR" is mentioned, it is implicitly understood that it contains both the VR and the brushes.
For the record, the VR and the brushes perform different functions, but for the sake of simplicity of maintenance, the modern VR contains both the VR and the brushes.
E Showell
Post by E Showell »
How long should an alternator go for? I'm guessing I'm on the original at 263 K miles.
'95 855 auto (sold)
Post by cn90 »
Alternators can die different ways:
- Worn brushes around 200K+.
- VR can go out any time, even when it is 1-2 years old, but the general consensus is about 130K-200K range.
- The windings (copper) seem solid but they can break and/or short-circuit with time/mileage.
At 263K, if this is original alternator, it is overdue.
E Showell
Post by E Showell »
Tested this evening at local auto parts retailer. Specs as follows:
Battery voltage: 12.44
Measured: 520 CCA
Rated: 500 CCA
Temperature: 46 degrees F
Starter
Cranking normal
Voltage 11.26V
0.0 amps
Time: 6.00 sec.
Charging system:
No load: 12.92V
Loaded: 13.34V
Within spec?
'95 855 auto (sold)
Post by erikv11 »
Battery resting voltage is within spec.
Voltage when cranking (11.26 V) I don't know about, never tested that.
For the charging system, the numbers seem a little low. On my cars, when I turn them on and then check the voltage at the battery it is always above 14, like 14.4 volts. However I have read that with all the electrical stuff on, that may drop to about 13 (but no lower).
You can get a very good look at the state of the brushes and the slip ring with the alternator still in the car, just pop off the black plastic cover (3 screws then some snap tabs).
'06 S60 R, 197k
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 19 times
Post by jblackburn »
I agree, your alternator output numbers look low. Should be 14+ unloaded; high 13's loaded.
My brushes were worn back around 180K...the interior lights flickered a little bit at idle...and it finally gave up the ghost in the 220's.
'98 S70 T5
2016 Chevy Cruze Premier
