1995 850 turbo 2.5 swap?
chris4256
Year and Model: 95 850 turbo
Post by chris4256 »
im looking to buy a motor for my 850 and got to wondering if i could use the newer 2.5 block. does the 2.3 head bolt right on? and are there any other modifications to be made? any help is greatly appreciated. thanks
Year and Model: Many Volvos
Been thanked: 75 times
Post by Ozark Lee »
What year and engine number are you looking to use?
chris4256
Post by chris4256 »
B5254t2. Just exploring my options on this. Out of an 04 v70
Post by Ozark Lee »
Anything can be done given enough time, money, and creativity however there are numerous differences in the '04 engine and the '95 engine you now have that really make it unpractical. For starters, the entire accessory mounting system is totally different and it would need to be modified.
The '04 engine is a CVVT engine which would be eliminated with the head change but I'm not sure if the passages on the 5254T2 mate up correctly with a 2.3 head or not. Even if the head does mate up, it is my understanding that the 5254T2 has thinner cylinder walls than the standard 2.3 and it really doesn't hold up well with higher boost levels. The compression ratio goes from 8.5:1 to 9:1 between those two engines as I recall which exacerbates the cylinder wall weakness issue.
chris4256
Post by chris4256 »
Ok. Thanks for the help.
