2000 V70 Fuel injectors not pulsing after replacing head
mstyflame85
- Year and Model: 2000 V80
Just finished a head replacement on a 2000 v70 turbo, there is pressure in the fuel rail, there's spark, the timing marks are both at 12 o'clock, (which is where they were before replacing the head). It seems like the engine is turning over slow, it was brought to me not running so I don't know if that's normal. When I put a test light on the injectors I'm not getting any pulsation. Any thoughts?
precopster
- Year and Model: Lots
- Been thanked: 128 times
Check cam sensor wiring and finally crank sensor wiring. Do they both have voltage with ignition ON?
- 1494 Views
Last post by 93Regina
- 597 Views
Last post by MoosePond123
