Hi guys... I finished my timing belt change and alternator rebuild and aside from a few hiccups along the way, all is well. Thank you all for taking the time to provide me counsel along the way...
Next up on projects to knock down is the PCV overhaul. There is some motor oil under the spark plug cover in the cavities of the head, some smoke escaping when the oil filler cap or dipstick is removed, and the oil filter looks a mess which leads me to believe the PCV system is clogged up... Everything else looks good and so far leak free and I'd like to keep it that way of course...
The crux is that I won't be able to do the full overhaul for another month or two due to time/funds but will still need the car for work, which is a very easy 12-13 mile return trip - all highway driving...
So my question is whether there is anything I can do with the PCV system that won't take the car out of service for more than a few hours per repair and won't cost more than a six-pack? I have everything in terms of tools and work in an environment in which I have access to all sorts of fasteners and tubing and wiring and so on and so forth, so am looking for a way in which I can get the system working somewhat efficiently for the time being until I can do a full-on replacement...
Any links, photos, advice, tutorials are much appreciated....
Also, that thin, brittle tube that runs from the box beside the PS pump to the top of the radiator, what is its function? I broke it when getting the alternator out on a cold day and have just Gorilla Glued it back together until I find another at a wreckers....
1997 855 base - PCV: what can I do pre-full overhaul?
- Year and Model: Many Volvos
- Been thanked: 76 times
if you leave the dipstick slightly out it will keep the crankcase pressure from getting too high and blowing seals but it may spew some oil. Try it and see what happens - check the oil often.
The tube with the accordion flex joint is a air line for the ECU/TCU cooling and it has very little pressure. Most of them on the road are broken. If enough of it is left you can wrap it with electrical tap and it will work fine. I just replace them, they are only about $10.00, but that is more aesthetics than function.
rmmagow
- Year and Model: V70 1998
- Been thanked: 2 times
On another V70 a friend owned we pulled out the dipstick a little, wrapped the pulled out section loosely with a rag and some electrical ties and he ran it like that for a while until the PCV could be done properly. Helped keep the blown out oil to a minimum and kept pressure from blowing out any seals.
1998 S70 135K - FOR SALE
2003 GMC Sonoma - 114K - POS
S373N
- Year and Model: 2012 Volvo C30 T5
Great idea with the dipstick.... I'm going to do that right now and grab a few extra quarts of oil to throw in the trunk just in case... Any cleaning that can be done to the system? Or lines that can easily be replaced with off-the-shelf tubing etc etc?
-2012 Volvo C30 T5 (white/auto/level II)
-2012 Nissan 370Z (pearl white/6-spd/touring/sport/nav)
rmmagow
Be sure to read up on the "heater hose" modification here. Once and done. My car is at 213K and the system was done using the heater hose thing. 60K or so of the 213K is mine and the PCV system is more or less perfect, sucks the glove in when I tested the system.
S373N
Beauty... Will do. I recall reading somewhere to not bother buying the kit from the websites and to instead cobble together the pieces from various sources for a better system and less money?
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
If the system is clogged, it likely has been that way for a while. Don't worry to much about it and don't drive it to hard until you get the system replaced.
thedancingfiddle
- Year and Model: 1997 NA 850 wagon
You could take out the flame trap if yours still has it in there. It might help a bit, and certainly couldn't hurt! Shouldn't be too hard to do, as long as you can get the hoses off the flame trap housing.
- Has thanked: 311 times
- Been thanked: 817 times
https://www.matthewsvolvosite.com/forums ... hp?t=53448S373N wrote:... I recall reading somewhere to not bother buying the kit from the websites and to instead cobble together the pieces from various sources for a better system and less money?
Be sure to read the whole thread, there are a few updates to the original post/method.
- 848 Views
Last post by SonicAdventure
- 1709 Views
Last post by vtl
- 967 Views
Last post by Blacklab467
- 172 Views
- 1916 Views
Last post by fisker247
