97 850 wiper malfunction
philippet
Year and Model: 2005 xc70
Post by philippet »
Hi everyone,
A couple of weeks back I lost the rear wiper - nothing moving anymore. Then yesterday the front wipers stopped working. Fuse is fine and there is some power: they only twitch a little bit every few seconds, even when the switch is off.
I am thinking the wiper relay went wrong. Does that make sense? Does the same relay control both front and rear wipers?
Thanks
Has thanked: 292 times
Been thanked: 765 times
Post by erikv11 »
I don't know what the problem is, but I can tell you there are two different relays for front and rear wipers.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
skloon
Year and Model: 94 850 95 850 04 S60
Been thanked: 2 times
Post by skloon »
bad ground on steering column ?
philippet
Post by philippet »
Thanks for the idea. The strange thing is that both front and rear wiper went out kind of gradually. First they were going weak for a while and then they both just stopped. Other electrical devices going through steering work fine, though.
The wipers tweak a little even with the relay out.
Post by erikv11 »
What about the fuses, is there only one or also two of those? I don't know about that one.
'06 S60 R, 197k
joe_pinehill
Year and Model: 850 1996
Post by joe_pinehill »
maybe its a bad ground, try removing the motor, cleaning the feet, and re installing. It happened on my 240, turned out to be a bad ground.
96 850 GLT
RIP '90 240 DL, 285K, someone ran a stop sign in front of me
RIP '89 760 Wagon, 200K
RIP '83 240 Wagon, rusted out
philippet
Post by philippet »
Turned out I just had to replace the wiper assembly. The twitching was just the motor trying to put back the wipers into place but struggling against the stuck little bearings. Thanks for your help.
