96 855 Direct radiator swap, manual to AT?
JimBee
Has thanked: 25 times
Been thanked: 42 times
Post by JimBee »
I have a good radiator pulled from an auto trans 850 and a leaky one in my 96 855 manual trans. Can I just plug the auto trans line couplings? Any other issues with that swap?
Matty Moo
Year and Model: 850, 1996
Has thanked: 1 time
Been thanked: 30 times
Post by Matty Moo »
You can swap it. The radiator part is the same, you won't use the AT cooler part so it's just going to sit there.
I manual swapped my 98, the original AT radiator is still in it.
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
JimBee
Post by JimBee »
Okay, great! But will I need to plug the AT ports?
Has thanked: 1497 times
Been thanked: 3810 times
Nope. Replaced my 1999 with a Nissens last year, and had the same question. Replacement radiator had ports for auto which weren't needed for my 5 speed.
Ports can just be left open.
JimBee
Post by JimBee »
More good news. Thanks, guys.
Year and Model: Many Volvos
Been thanked: 75 times
Post by Ozark Lee »
You don't need to plug the ports. If you can find a couple of rubber caps to hose clamp on then it would prevent the coolant from leaking if the cooler sprung a leak. Since the cooler itself isn't under any pressure the chances of it leaking are pretty small but capping them falls into the "It can't hurt anything" category.
