1999 s70 non turbo. Manifold removal part 2
Chevtex5
Year and Model: 1999 s70
Post by Chevtex5 »
I am removing my manifold to get at my pcv parts for replacement. Manifold is loose and disconnected.
I have a hard fuel line snaking through the manifold with a 90 degree bend. Thanks to precopster, I was able to disconnect the quick connect fuel line fitting.
However, the 90 degree bend in the hard line through the manifold seems too long to get the manifold past.
Should I attempt to bend the hard fuel line to get it through the manifold? Should I cut the hard fuel line and later reattach with rubber hose? Is there a better way to get the manifold off?
Thanks!
Bluevanacd2005
Year and Model: 1983 760
Post by Bluevanacd2005 »
Don't cut it. If I remember right you can bend it just a little and twist the manifold to get it off.
Spenser
I like curves on my women, not my cars
burnout8488
Year and Model: 1999 S70 AWD
Post by burnout8488 »
Yeah, just jockey the manifold around. It comes out around the fuel pipe. You might scratch the paint off the fuel pipe but that's nothing.
'13 BMW X1 35i M-Sport
'99 S70 AWD/FWD - 198K - FOR SALE!
