98 V70XC Acts like key is still in ignition
I'm having an issue where I go to lock the doors with the remote, but nothing happens. Then if I get back into the car it's making that chime noise like the key is still in the ignition, so then I have to put the key in, turn it to on, back off again, and then the noise stops and I'm able to lock the doors. Anyone know what's going on here??
mecheng
- Has thanked: 15 times
- Been thanked: 21 times
I have the same problem occasionaly, I lubricated the lock with some dry graphite.
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
- Year and Model: Many Volvos
- Been thanked: 75 times
The electrical portion of the ignition switch is a known weak link. In Volvo terms they are fairly cheap and they are very easy to change. As they fail all kinds of weird things happen like all of the warning lights coming on, all of the lights going off, and your problem where the key reminder chime continues to sound.
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 93 times
- Been thanked: 146 times
Although the electrical portion of the
ignition switch is indeed renouned for
causing strange behavior when it fails,
it's worth noting that the tiny switch
that senses if your key is in the lock
cylinder is a separate unit.
I'd second the suggestion of some lube.
- BEJinFbk
After spending a little time crawling through diagrams,
I'm not finding that separate switch for "key in" detection.
I was hoping to post a pic tonight, but it's getting late...
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 19 times
Graphite spray! Mine did this once.
'98 S70 T5
2016 Chevy Cruze Premier
