230,472 Miles
$600 black
$ free labor due to all helpful posts for DIY volvo 850s. Thank volvo fam. I'll post pictures of my baby soon
150-151 compression on all 5 cylinders
Parts Purchased/Completed
IPD Performance Coil Wires $89.95
FCP Distributor Cap $33.95
FCP Distributor Rotor $20.95
Advance AUTO E3 Spark Plugs $31.09 - my opinion best plugs on market and cheapest in price TRY IT
IPD (2) Oil Cap Seal $9.95
IPD (2) License Plate Lens $19.06
FCP trunk lift shock $16.99
ARD injector service tool $19.95
ARD (5) injector kit $27
FCP PCV Breather Kit $162.36
FCP Engine Mount Kit $122.22
FCP Control Arm Kit $180.03
FCP Oil dipstick lower seal $1.11
FCP intake manifold gasket $15.90
FCP steering bellow kit $16.95
FCP inner tie rod $29.90
FCP transmission dipstick $7.95
FCP Fuel filter $12.95
FCP oil filter $4.75
FCP Timing Belt Kit $282.84
FCP ECU Cooling Tube $11.95
FCP Antenna Mast $15.95
FCP EGR Valve Gasket $4.95
FCP Throttle Body Gasket $1.49
FCP Braided Vacuum Hose $12.82
FCP Oil Pump Gasket $23.95
FCP Washer Filter $6.95
FCP Expansion Tank $24.95
FCP Poly Torque Rod $39.95 - excessive vibration when out of park
IPD Phenolic Intake Spacer $69.95
= $1828.81
Future Upgrades/Replacements:
IPD HD (4) Subframe Bushing $140.20 or delrin bushings $180
IPD Poly Subframe Insert $68.95 - option if i don't replace entire bushing
IPD (2) Seat Belt Button $11.95
IPd Turboback exhaust $995
IPd 302 mm brake upgrade bracket (Front) $95.60
Volvo R Green fuel Injectors/rail
$135
Ebaymotors.com
Volvo R Exhaust Manifold
$197
Ebaymotors.com
ARD Green Tune
$340
Ardtuning.com
ARD Lightweight Crank Pulley
$114
Snabb.com
iPd HD Compressor Bypass Valve
$69.95
ARD 16T compressor wheel $125
ARD Super back rebuild kit $157.29
ARD 11 blade turbine wheel $215
RZ Intercooler $675
The Bad:
Bank 1 sensor 2
Left side of dash lights out
Need Transmission flush - dark colored
Need Brake Fluid Flush - black colored
SS Brake hose change
