1995 Volvo 850 Horn AND odometer don't work. Related?
joemichaels
Year and Model: 850 1995
Post by joemichaels »
My daughter bought a 1995 Volvo 850 (nonturbo) last fall.
The horn never worked -- and, alas (we learned) neither does the odometer.
Is it possible that these are related? Any suggestions to remedy?
I pulled the airbag and cleaned the horn contacts...#34 fuse is fine.
tryingbe
Year and Model: None
Has thanked: 1 time
Been thanked: 26 times
Post by tryingbe »
Odometer doesn't work is probably due to a broken gear.
Horn never worked could be wiring or horn themselves.
85 GLH, 367 whp
00 Insight, 72 mpg
Year and Model: Many Volvos
Been thanked: 75 times
Post by Ozark Lee »
Check to see if the horns are plugged in. A very common problem on the 850s is for the plastic insulators on the horn "button" on the steering wheel to break. When that happens the horns can often stay on all the time so people just unplug the horns altogether. The odometer gears, as was pointed out, are also a problem area and they too have a nearly 100% failure rate.
The good news is that it is one stop shopping to fix both problems. Odometergears.com sells both replacement gears for the odometer and a repair kit for the horn switch.
We a very good tutorial in the repair database on replacing the odometer gears
Odometer fix how to Be sure to read the comments as well since they have several tips that make things easier and they also cover some things not covered in the tutorial.
Odometergears.com has very good documentation to go along with the horn repair kit and that repair is even easier.
polskamafia mjl
Has thanked: 19 times
Been thanked: 21 times
Post by polskamafia mjl »
+1
Horn and odometer gear are guaranteed to fail eventually in every 850. Both are easy repairs.
