1999- C/S/V70 Troubleshooting Coil 30713416 with ETM system ME7
Has thanked: 1497 times
Been thanked: 3809 times
Keywords coil on plug pin assignments
Volvo part number 30713416
Quick post on troubleshooting the 'coil pack' system used on later P80 models - these cars have a coil over each cylinder and no distributor.
Removing coils - see pix below
Coil Pinouts and Measurements
1 Signal in from ECU ( coils re fired individually by the ECU grounding this pin)
2 Ground on trigger transistor
3 Ground on HV line
4 12 VDC supply.
I measured all pins INF Ohms on MOHM scale except
Pin 1-3 = 852 Ohms
View down Spark plug hole
Pop Coil up grasping body firmly
Remove 10mm bolt holding down coil - QTY 1 per coil
Remove covers and expose 5 coils
Two clips (front back) release Timing belt cover
Torx T30 bit, remove and save 8 screws from cam cover
View of the coil system on ME7 cars
Coils are always 12 VDC hot to pin 4 when Ignition is on.
ECU grounds coil on command at pin 1 for each coil independently.
Its important to have the M6 (10 mm) bolt tight to ground these well.
ME7  coil electrical diagram
Kazthebassman
Year and Model: C70 1999
Has thanked: 2 times
Post by Kazthebassman »
Can anyone tell me where pin 5 on the ETM terminates. I know it is at ground potential with ignition on but I would like to know where it actually lands. It appears the ECM may be turning on the ETM by supplying ground to pin 5 of the ETM.
I see it's destination is designated "31/91" on this diagram. My problem is intermittent so simple voltage measurements may not suffice.
31/91 is the designation for the connector for pin 5 ETM. Note on your car the connector will be buried under the intake manifold, not on the back left as indicated on the diagrams.
I think that is as permanent ground and Is not switched by the ETM
Adding Complete circuit per Alldata to complete info
