1994 850T Tempertaure guage ECT low
cBobs94850T
Year and Model: 850 1994
Post by cBobs94850T »
The ECT has decided to randomly function. Sometimes it read the proper temp (3 O'clock position ) sometimes just barely off the bottom, then nothing. I have no error codes in A2, and I cannot read any in A6 light doesn't even light. Is this indicative of a faulty ECT or could there be something going on. Also is there a fix for the A6
thanks
Year and Model: Many Volvos
Been thanked: 75 times
Post by Ozark Lee »
On a '94 turbo you have a Motronic ECU and all of the codes are read through A-2. A-6 is only used on the older N/A cars with the LH 3.2 system.
Check the connector on the ECT sensor for corrosion or a broken wire if it is intermittent.
cBobs94850T
Thank you Lee will check the connector
But lately it's been reading just slightly off the bottom, then falls to the bottem and back to slighty above
The RPM spike when it does this.
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 19 times
Post by jblackburn »
cBobs94850T wrote:Thank you Lee will check the connector
That's interesting. I'd hunt around for a corroded or loose ground strap, either by the ECU box or battery.
'98 S70 T5
2016 Chevy Cruze Premier
cBobs94850T
Thanks jblackburn
polskamafia mjl
Has thanked: 19 times
Been thanked: 21 times
Post by polskamafia mjl »
I have a similar issue. Tach, fuel, and coolant gauges will work intermittently with coolant being the least likely to work usually. Its worst when its hot outside. Usually I can flick the malfunctioning gauge and it'll come back on. I think the clusters wear out after almost 20 years on the road. I have a working used cluster I'm going to install; hopefully that fixes my problems.
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 111 times
Post by E Showell »
That could also be a sign of incipient ECT failure. If there is no corrosion in the connector and no degraded wiring, I'd be looking to replace that ECT and thermostat asap.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
Year and Model: 2004 V70 2.5T
Been thanked: 471 times
Post by cn90 »
How old is the thermostat?
If you replace, use only Wahler.
jreed
Has thanked: 352 times
Been thanked: 192 times
Post by jreed »
A couple of months ago I replaced a failed FAE ECT. I measured it and found it was reading too high a resistance compared to specification. I put up a graph and some inspection photos here:
https://www.matthewsvolvosite.com/forums ... =1&t=61920
I installed an OEM ECT sensor and it has been working fine since.
