98 V70XC Keeps pulling to right
jmana
Year and Model: 04 xc90
Post by jmana »
I really don't understand what is going on with my car. I've had it to the alignment shop 3 times and it sill pulls to the right. I changed out the control arm, strut mount, even calipers. I've asked the alignment place if there is anything loose, worn, or on the verge of needing to be replaced but they said no, everything looks great. The only thing he did say is the camber can't be adjusted and the one side is about a degree different than the other. The other weird thing is when braking the steering wheel jerks to the left a bit. It's gotten better since replacing the parts, and since the third time at the alignment shop, but it still does it. Is there anything else I should consider?
Has thanked: 1500 times
Been thanked: 3812 times
Dragging brake pad, stuck caliper, warped wheel, bad wheel beating, bent frame.
Is the right wheel hot after driving? Compare to left, don't touch rotor with hands though...don't ask...
jmana
Post by jmana »
Pads look brand new, calipers just changed, no dragging, even checked rotors with a non contact thermometer. Bearings fine, never wrecked. Like I said, I'm stumped....
850 LPT
Year and Model: 96' 850
Has thanked: 331 times
Been thanked: 242 times
Post by 850 LPT »
Tires can do this, even brand new ones. Rotate them and see if that makes a difference.
58' Porsche Diesel Junior
13' Honda Odyssey :oops:
jmana
Post by jmana »
Yeah, forgot to mention, I did rotate the tires too. They are directional Michellins so I couldn't cross rotate them, but I did what I could.
regent
Year and Model: 2015 XC60 T5
Has thanked: 2 times
Been thanked: 12 times
Post by regent »
jmana wrote: I changed out the control arm, strut mount, even calipers.
Did you only change one control arm or both?
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired :(
1987 340 DL - retired :(
jmana
Post by jmana »
One, the other one is fine. The passenger side one had quite a bit of play in the bushings.
rmmagow
Year and Model: V70 1998
Been thanked: 2 times
Post by rmmagow »
Change the other one too. Even if they are both VOLVO, no guarantee they are from the same mfg. I had a similar problem with a Mazda a couple of years back. Changed both to the same brand and all my pulling went away. Camber can be tweaked by loosening up things and trying to move the strut a little bit. An alignment shop should know a bit about this. Not an official adjustment, just using built in play to move things around.
1998 S70 135K - FOR SALE
2003 GMC Sonoma - 114K - POS
Year and Model: 2004 V70 2.5T
Been thanked: 467 times
Post by cn90 »
You should post the alignment sheet data so others can help.
kahl
Year and Model: 2000V70XC
Been thanked: 10 times
Post by kahl »
any slop in the trailing arm components?
