2002 V70 XC Gas leak
- Mike Langlois
- Year and Model: 2002 V70 & V70 XC
- Has thanked: 28 times
- Been thanked: 6 times
WE have a 2002 V70 XC that has a gas leak on top of the tank. I saw the posts on the 98 model and they were a great help. Does any one have any advice on pulling the rear axles? Seem to be hard to find manuals for the particular version of the car. I want to drop the rear differential in order to access the gas tank and replace the damaged lines. Mike
wouterve
- Year and Model: 2004 XC70 / 2018 XC6
Are you sure it’s the hoses? There was a problem with the fuel pumps on these, leading to a recall. A fuel leak is one of the possible symptoms:
Here is a copy of the letter that went out to owners: http://www-odi.nhtsa.dot.gov/acms/cs/ja ... 3-2016.pdfVehicle Make / Model: Model Year(s):
VOLVO / S60 2001-2004
VOLVO / S80 2001-2005
VOLVO / V70 2001-2004
VOLVO / XC70 2001-2004
VOLVO / XC90 2003-2005
NHTSA Campaign ID Number: 09V483000
Summary:
VOLVO IS RECALLING CERTAIN MODEL YEAR 2001-2005 S80, MODEL YEAR 2001-2004 V70, S60, XC70 AND MODEL YEAR 2003-2005 XC90 VEHICLES SOLD IN OR REGISTERED IN THE STATES OF ALABAMA, ARIZONA, ARKANSAS, CALIFORNIA, FLORIDA, GEORGIA, HAWAII, KENTUCKY, LOUISIANA, MISSISSIPPI, NEVADA, NEW MEXICO, NORTH CAROLINA, OKLAHOMA, SOUTH CAROLINA, TENNESSEE, TEXAS, UTAH, VIRGINIA AND THE U.S. TERRITORIES. WHEN EXPOSED TO CERTAIN ENVIRONMENTAL CONDITIONS (HOT CLIMATE AND TEMPERATURE CYCLING) OVER TIME AND IN COMBINATION WITH VARYING FUEL QUALITY, THE FUEL PUMP CAN DEVELOP CRACKS IN THE FUEL PUMP FLANGE.
Consequence:
IF THE CONDITION OCCURS VEHICLE OWNERS MAY NOTICE FUEL SMELL AND/OR FUEL LEAK WHICH, IN THE PRESENCE OF AN IGNITION SOURCE, COULD RESULT IN A FIRE.
Remedy:
DEALERS WILL INSPECT THE FUEL PUMP INSTALLED IN THE VEHICLE, AND IF NECESSARY REPLACE THE FUEL PUMP WITH A PART OF A MODIFIED DESIGN. THIS SERVICE WILL BE PERFORMED FREE OF CHARGE. THE SAFETY RECALL BEGAN ON JANUARY 15, 2010. OWNERS MAY CONTACT VOLVO AT 1-800-458-1552.
Notes:
VOLVO SAFETY RECALL NO. R220. OWNERS MAY ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY 1-800-424-9153), OR GO TO HTTP://WWW.SAFERCAR.GOV .
jking4020
- Year and Model: 1997 850, 2001 v70xc
- Been thanked: 3 times
I got same car. Fuel leak coming from top center of tank. It wont start if it gets under ¼ tank. And it runs rough now since i broke a small chip off of a red injector washer when i did the pcv job. I checked the fuel pump and nothing wrong there. Is the reason it runs bad cause of a small air/vacume leak at the injector with the cracked washer?
- dlundblad
- Year and Model: 2002 S60 2.4t
- Has thanked: 6 times
- Been thanked: 4 times
Assuming the XC70 is configured like the S60, I would start by pulling the rear seat cushion and check under the access holes for leaks.
If you do need a new pump, I recommend you get the lock ring tool.
Hers: Charcoal 2002 S60 2.4t 187k
- 844 Views
Last post by puntmeister
- 23 Replies
- 7715 Views
Last post by MrAl
- 3228 Views
- 2131 Views
Last post by dosbricks
- 1192 Views
