2009 Volvo S60 AC blows hot after smoke coming from radiator
Help, Advice, Owners' Discussion and DIY Tutorials for the groundbreaking new Volvo S60 2011+, V60 2015+ XC60 2010-2018.
jackfish28
Year and Model: 2009 Volvo S-60
Post by jackfish28 »
I have a 2009 Volvo S60 with over 100k miles on it. Yesterday when I was driving back from New Orleans I stopped to get a coke at a gas station and when I came back to the car smoke was coming from under the hood. I opened the hood and I would have sworn I had a busted radiator or leak. But it is a new radiator as I hit a box on the road in November and all of this was replaced. And the car was not runningt hot, and no water leaking or anything leaking. Several mechanic guys stopped and helped we look over the car and determined no leaks anywhere, and engine was not running hot and that is was something electerical or I picked up some plastic that was burning off the radiator. I drove about another 20 miles and determined that the AC was not blowing cold air at all. On the way to New Orleans three hours earlier it was almost too cold. Any idea of what this could be? It was something right on or next too the radiator. It blows hard but there is clearly no freon cooling the air.
Steve in mobile
jimmy57
Been thanked: 320 times
Post by jimmy57 »
If the electric cooling fan was not working (unplugged when rad was replaced) then the A/C high pressure will go really high and can blow out refrigerant from a relief valve. The compressor will be switched off if pressure goes to 440 psi but the relief valves can dump before the compressor is shut off.
My suspicion is your smoke was refrigerant release.
The car can idle for a few minutes with no fan and not run hot. The fan does not run at all if you are moving 25 mph or above.
jackfish28
So you think the electric cooling fan is the problem? I have run the ac many times since then. Could it just have gone out? Does it have a fuse or something?
jimmy57
Post by jimmy57 »
I listed one scenario. If the a/c is on and the car is sitting still then the fan will be on if the temp outside is over 75. Have you been hearing the fan?
If you didn't idle very long then fan can be out of action and there would be no problem. Leaving it running and going into a convenience store is long enough for it to overpressure without fan running.
jackfish28
Got it thanks
speedyt5
Year and Model: s70 t5, 1999
Been thanked: 2 times
Post by speedyt5 »
You definitely busted an a/c hose. When the smoke came out it was refrigerant from the hose. The hose or fitting wherever it may be that broke sent the refrigerant out which can be mistaken for coolant. The reason the A/C is blowing hot is because there is no refrigerant.
