Hello,
My leather was badly cracking so I pulled a less cracked leather seat from a junk yard. 2 of the 3 seat directions adjust fine. The front and back to do not work however. When I put the seat in, it initially worked briefly (both forward and backward). Now all I get it a clicking when I try. There is plenty of track left to go forward and backward, nothing is blocking the seat from moving forward or backward either. The seat did come from a slightly newer car but I can't see that being an issue. I'm out of ideas. Thanks.
1994 850 Seat swap gone bad
- dosbricks
- Year and Model: '96 855, '98 S70
- Been thanked: 2 times
The clicking noise doesn't sound good. Any possibility one track could be binding enough to put it out of alignment with the other? Did you tighten the rear bolts first (lift the rear of the seat slightly as you tighten)? You might try loosening all the bolts to confirm there is no binding. Also might try putting down a lot of newspaper and spray the tracks with some white grease. If that doesn't do it, as a long shot, you might try swapping out the controls (possible low voltage due to corrosion)? Worst case, you can remove the good leather from the new seat and put it on the original one. I did that to our 850.
And BTW, welcome to the forum!
difflock54
- Year and Model: V40 Nordic 2002
- Has thanked: 7 times
Check the operating switch as stated above.
Also, is it possible to swap over the forward/backward electric motor units betwen the 2 relevant seats?
The clicking could be a stripped or badly worn drive gear not engaging inside the salvaged seats motor unit.
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 111 times
I've got some extra seat motors from a V70 I'd be willing to part with if they turn out to be the problem. PM if interested.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
- osman
- Year and Model: 2002 c70 hardtop
It usually the switch that goes bad and the front to back is the first function to go, these motors nearly NEVER fail. Try pressing the front/back switch inward when trying to move it and be patient, sometimes it will take a few seconds then start moving. Sometimes the plastic sheathing around the seat motor cables needs to be shortened but this problem occurs in the 960's much more than the 850's/ The seat control panel can be easily removed from another seat and voila.
Brick Life
2003 Saab 9-5 ARC V6 3.0 Turbo 120K SwagWagon
97 850R wagon mileage unknown
2000 C70 Turbo Convertible 110K
99 XC70 AWD LPT 115
98 BMW 328IS 130K M3 Wheels
94 Mercedes 420E 160K
Kiwi bluetooth/Torq Pro app VOL-FCR/VAG-COM USB cable
99 XC70 AWD LPT 115
- E Showell
Yeah I'd be surprised as well if it were the motors.
'95 855 auto (sold)
'95 855 auto (sold)
Thank you everyone...I tried some of the suggestions. I made sure the bolts were not tweaking the rails and causing a bind, but that was not it. I made sure nothing was rubbing, yet again, and nothing was. I then tried to move the seat to one of the stored position in the memory and I was surprised to see it move both forward and backward when all along it seemed stuck in place, at least while trying to use the switch. I then remembered that I still had my old control switch (from the old seat) and I put it in, next think I know I am moving all over the place. There is still some vibration when I move the seat front to back, but it moves without any serious hesitation. I'm gonna call it good from here, thanks guys.
