1998 s70 Pulling towards right
raykan
Year and Model: 1998 S70 GLT => 236K
Post by raykan »
my s70 is always pulling to right, even after alignment service. I talked to guy who did alignment, he couldn't say anything other than the car's alignment is good and he also realized during test drive that car has tendency to pull right.
Tires are a year old and balanced.
What would be the reason?
deepsouth
Year and Model: 2001 Volvo XC70
Been thanked: 8 times
Post by deepsouth »
Need more details. Pulls to the right while braking? Pulls to the right when steering wheel is straight and you let go? Steers straight while wheel is turned to right (or left)?
Have you tried swapping front wheels in an effort to eliminate tires?
Eric
2000 S70 GLT SE, 175,000
2001 XC70, 129,000
MoVolvos
Has thanked: 310 times
Been thanked: 524 times
Post by MoVolvos »
raykan wrote:
my s70 is always pulling to right, even after alignment service... What would be the reason?
Can you provide the Before and After Specs? My hunch is the Castor is higher on left and is unfortunately not adjustable. Most shops won't tweek the Camber either so they'll just "set the toe and let go".
_
rmmagow
Year and Model: V70 1998
Been thanked: 2 times
Post by rmmagow »
And check your tire pressures. Mine would feel like a slight pull when one tire was about 15# under all the others due to a bad valve.
1998 S70 135K - FOR SALE
2003 GMC Sonoma - 114K - POS
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 111 times
Post by E Showell »
Thrown wheel weight and dragging brake caliper are other possible causes.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
rmmagow
Post by rmmagow »
If you have a infrared temp reader you can easily find a dragging brake by driving for a while, stopping and pointing to the same relative spot towards the center on each wheel, I generally use a lug nut. A dragging brake will read a much higher temp on a dragging wheel.
