Dexron IV & V?
MoVolvos
Has thanked: 310 times
Been thanked: 524 times
Dexron IV & V?
Post by MoVolvos »
_
Below is the original post and then a link with information on the Dexron IV & V. Perhaps the info in the answer link is true and also perhaps the OP meant to write Dextron VI instead of IV. Those Romans :)
1998 V70XC Can i use Dexron IV in my automatic transmission?
https://www.matthewsvolvosite.com/forums ... =1&t=63735
Dexron IV & V?
http://www.bobistheoilguy.com/forums/ub ... er=3144917
_
jimmy57
Been thanked: 320 times
Post by jimmy57 »
Dexron VI (Dexron 6) is the new stuff that is synthetic or of high enough conventional oil stock to be nearly synthetic. It is lower viscosity also.
It is supposed to be backwards compatible according to GM but other manufacturers have not blessed it for use in their older gearboxes.
I'm not so sure it is great replacement for the thicker stuff in Volvo 4 speed transaxles.
hausmeister
Year and Model: 1995 850T5-R
Has thanked: 250 times
Been thanked: 77 times
Post by hausmeister »
The question is if the transmission can even benefit from such a high quality oil?
I recently did a flush with Liqui Moly Top Tec ATF 1100 (on the website they recommend either 1100 or 1200 in their database) and the Transmission is working very good. It is nothing special and dexron III, but meets the volvo sepcifications. I guess anything that meets the volvo specs should be fine.
850 T5-R '95 auto Image
