Volvo 850 ABS light after brake fluid flush
Baptiste1106
Year and Model: 850 1994
Been thanked: 2 times
Post by Baptiste1106 »
Anyone know why the abs light would come on after a brake fluid flush? I used the motive power bleeder, not the pedal bleed process.
motive power bleeder.jpg (6.27 KiB) Viewed 280 times
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
May have air in the system somewhere.
Baptiste1106
@rspi ..... i did notice air bubbles coming from only the rear drive side. Bubbles were endless so i moved on. Car brakes/stops fine. Any reason why air would only come from one side?
rspi
Post by rspi »
I have no idea. The bleeding order is, RR, LR, RF, LF. I would drive it for a week or 300 miles, then bleed the calipers, and see if that helps.
Baptiste1106
Yea i followed that exec bleed process, but i will drive for a bit and re-bleed. Thanx
