2006 XC90 A/C Compressor...solutions?
whywontthisrun
Year and Model: 2006 XC90 AWD
Post by whywontthisrun »
I tried recharging my A/C, same as I do every year. I used A/C pro (http://i.walmartimages.com/i/p/00/04/81 ... 00X500.jpg [1] ).
I attached it to low pressure port. The pressure gauge on the canister showed it steadily increasing from 10-25PSI, but right as it got into the green zone, I heard what I thought was my A/C line go. I checked all necessary parts with UV light/leak detector, but didn't see anything.
I tried recharging again a few weeks later and the same thing happened...rose from 10-25PSI and lost pressure. I turned car off and tried it again....same thing.
I think it's a compressor problem...
Does anyone have any ideas?
Year and Model: 2004 V70 2.5T
Been thanked: 471 times
Post by cn90 »
Put dye in system and find out where it leaks.
whywontthisrun
Like I said, I checked all necessary parts with UV light/leak detector, but didn't see anything.
jimmy57
Been thanked: 320 times
Post by jimmy57 »
Was the fan on radiator running when you were doing this?
If your fan doesn't run to pull air across the condenser then the high pressure gets excessive and the pressure relief valve dumps refrigerant.
