2000 V70 clutch strange sound
any ideas. in this video Im keeping my clutch pedal at the middle and car is starting to run. thanks
- Has thanked: 1502 times
- Been thanked: 3813 times
It sounds like a bad release bearing. That is only loaded when declutch (foot down on the floor) or taking load on the pressure plate. If it stops promptly when your foot is lifted, thats probably it.
Remedy is removal of transmission and replacement release bearing. If miles are high, you might want to do the clutch plate but definitely the rear main engine oil seal.
Hmmm. Bad release beRing will make noise in any gear, only dependent on pedal position
The good news is if it's clutch plate you still drop the transmission to deal with it.
Release bearing, disc, rear engine seal while you have the chest cut open, to coin a phrase from surgery.
