2001 V2001 v70 2.4T Diagnostic help - CEM-1A5D / CEM-1A62
Harleyvh
Year and Model: 2011 S60 T6 AWD
Post by Harleyvh »
Situation:
I just had the timing belt / water pump changed and following the installed, the car does not start.
Here are the DTC codes:
== 14 modules responded to DTC query ===
BCM (Brake Control Module): No DTCs
CEM_H (Central Electronic Module): 2 DTCs
--> CEM-1A5D: Communication with the electronic throttle module (ETM). Signal missing.
--> CEM-1A62: Communication with the engine control module (ECM). Signal missing.
TCM (Transmission Control Module): No DTCs
CCM (Climate Control Module): No DTCs
PSM (Power Seat Module): No DTCs
CEM_L (Central Electronic Module): 2 DTCs
DDM (Driver Door Module): No DTCs
PDM (Passenger Door Module): No DTCs
REM (Rear Electronic Module): No DTCs
UEM (Upper Electronic Module): 1 DTC
--> UEM-003D: Cargo compartment lighting/3rd row reading lamps. Faulty signal.
SWM_L (Steering Wheel Module): No DTCs
DIM (Driver Information Module): No DTCs
SRS (Supplemental Restraint System): No DTCs
AUM (Audio Module): No DTCs
The car has been running with a autotech tune and the tune was "in" prior to the timing belt change.
There is spark however no injection.
Battery is fully charged and plugged in a battery charger
Car starts if gas is put in the throttle boddy / manifold.
My local volvo mechanic (been in the business for more than 20 years) does not understand what is this problem...
just read this post:
http://forums.t5d5.org/topic/23565-majo ... #82081a62=
it seems that his issue was fixed by swapping the starter and engine relays
"By swapping the engine relay and starter relay over in the engine bay fuse box - MA1 and MA3, the dash messages have gone at IGN II and it has started first time!"
not sure if this applies to my situation though...
Any help would be appreciated
thanks
2001 V70 2.4T - RIP
2011 S60 T6 AWD - In progress
2004 V40 - "backup"
jenkinskg
Year and Model: 04 c70 hpt 98 s70 xc
Has thanked: 1 time
Post by jenkinskg »
I bet one relay or both were lose.
My rad fan not turning on, but vida can turn it on manually
2004 c70 2.3HPT, s60 2.5T
