96 850 Non Turbo Potential Issues?
tourspin69
Year and Model: 96 850
Post by tourspin69 »
New to the board. Just picked up a sweet...Florida 850 non turbo with only 74K. I want to keep this car for sometime. In fact, it will be my 15 year olds first car. I would appreciate any input on things to look for..keep up with etc.. I'm a weekend warrior DIY guy. I do have my limits though!
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
tourspin69
Thanks. Again only 74K....unfortunately no record of Timing belt change. However, here are some pictures...thoughts?
Has thanked: 1611 times
Been thanked: 4075 times
Timing belts get replaced on both time and miles, so you should put this on the to do list. It sucks when they break, as in 2000 USd of head repair, so you have to divide your risk aversion factor by your karmic score to achieve your timing belt replacement priority score. Use SI units please, these are European cars.
Don't forget to tell everyone the Tech Valley area is too crowded. I'm off exit 23.
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
Timing belt and tensionors MUST be done before you even drive it.
It's a time bomb waiting to explode at these years
rspi
Post by rspi »
I wouldn't even start the car before changing the timing belt (all parts). If you have to move the car have it towed.
tourspin69
Thanks. I will have it replaced. Great just to start from scratch with this car. What's typical cost of timing belt/water pump at a private service shop? $800-1000
Probably 500-600 at Randall Volvo ( independent) in Renssalaer. Heartily recommended
Jedlacks
Year and Model: 850 97
Post by Jedlacks »
I have enjoyed owning my 97 850 from new, and I have also bought all the tools needed to do basically everything on the car. The only thing I have not done is the transmission and an engine rebuild. If you are so inclined, try to get your elbows greasy. If is starts to have minors issues you could easily grow despondent handing over cash to the mechanics.
tourspin69
Thanks for all of the info. This is my 7th Volvo. (740, 850, S70, V70, S40, XC 70). I specifically looked for an 850 because it was my favorite of them all. I used to just pay for service on those cars...over time I became a bit more brave after I replaced an alternator in the s40 by myself and saved about $500. I may even venture to replace the timing belt on my own.
