1998 V70 AWD Missing unidentified connector
jadnhm
Year and Model: 2008 XC70
Post by jadnhm »
Hello all, need some help.
I have 1998 V70 AWD with the weird saddle tank that has fuel lines running all over the top of it. I had a leak up there, and dropped the whole setup to fix the leak.
Putting everything back up to the car I found I'm missing one of the electrical lines that runs through the panel in the floor of the hatch/wayback.
It is a small 2-pin grey connector. The harness side has BL/W (blue with white stripe) and BL/R (blue with red stripe) wires. I cannot for the life of me find the line that's supposed to hook back up here.
If I knew what component it went to on the other end I could try finding that and tracing my way back...
I have all the other connectors:
- yellow 4-pin for the ABS sensors
- grey 3-pin for the tank pressure sensor
- red sheathed line for fuel pump assembly with power for fuel pump and two sets of sending unit lines
I can't find this in the wiring diagrams at all. I cannot see the connector.
Anyone who knows what this line is and how I might find it will really give me a big boost.
Thanks.
